T
thekingiam
was looking at a tt cu and the main earth goes outside into a concrete driveway cable looks quite small, is the minimum cable size requirement the same as other earthing arangements?
if i do need to replace, would i need to provide inspection pit.
its being protected by a rcd,could i use rcd as means of isolation while changing cu?.
testing earthing arangement could i do earh loop test on my multimeter instead of having to buy electrode tester?
