Reverting from LED lighting to Halogen | Page 2 | on ElectriciansForums
Discuss Reverting from LED lighting to Halogen in the Lighting Forum area at ElectriciansForums.net
I don't think that getting rid of the dimmer switches so that the leds are always on maximum brightness would solve the problem, because then firstly they would be super bright, but then also I think they still flicker even on maximum brightness. Is that not right?
If it's of any interest, following replacing all of my GU10 halogens with LED I have about 50 halogen ones in my cupboard...you can have them for nothing, or the postage...
Pirate, that would be fantastic if you didn't mind. To be honest I did wonder if there were stacks of halogens heading for the bin as people switched to LEDs. I'd be really glad to give some a new home.
If I go and have a look on Saturday could I get back to you? I'm not sure if they are GU10s until I take a look.
Thanks!
They shouldn't flicker on full brightness. This needs sorting out first.
That article says that they still flicker on full brightness as long as they are driven on AC current. It says only if they are driven on DC do they stop flickering. Do you not agree?
Caveat is that I'm not totally sure that it is the flicker. I also have trouble with very bright screens with CCLF backlight so full brightness on non-flickering LED bulbs may be tricky too. I get on fine in daylight and with Halogen bulbs, 300W turned up to max.
It would be handy if I at least had a fairly immediate reaction so I could do several tests, but it takes an hour to kick in and then I feel rubbish for ages, so doing lots of tests if a bit tricky.
I think that the LED lights or whatever replaces them will be fixed so that it doesn't cause problems any more. There are huge numbers of people having problems with LEDs and the designers are working on it. It was the same when CRT screens first came out, until the fixed the refresh rate, and again the same when fluorescent strip lights came out. I reckon I just need to hang on to the old technology until the new technology gets fixed.
There are some people who still struggle after the technology is considered to be fixed though. Those would be people who struggle with migraines all the time for example. Some of them are just having to live in a world that is lit by types of light that their eyes can't cope with.
I go to many customers property's most have the old energy saving lights .they may has well get a Davie lamp . [ElectriciansForums.net] Reverting from LED lighting to Halogen they are now mass producing candles again when their in no light .
We still have bayonet fit energy saving lights. I like them, though I have recently added a couple of 300W halogen uplighters as I realised we were basically sitting in darkness. My corner shop still sells incandescent light bulbs.
As a matter of fact, a halogen uplighter is probably the obvious solution for my current problem. I could just put one in each room and turn off the other lights.
Reply to Reverting from LED lighting to Halogen in the Lighting Forum area at ElectriciansForums.net
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
