Ring circuit cable length | Page 2 | on ElectriciansForums
Discuss Ring circuit cable length in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A 100mA RCD might trip before a 30mA RCD depending on the type of fault and the characteristics of the RCDs.
To ensure discrimination the 100mA RCD would need to be time delayed i.e type S.
If I were installing I might tend to go for an upfront time delayed 100mA RCD and then a split load Dual RCD board, though obviously RCBOs would be better if you can get them in double pole versions.
If you had good Ufer earthing and the resistance to earth was then low enough to trip your MCBs then you would be OK with just RCBOs.
How low would the resistance to earth have to be to trip a neutral to earth fault? My home has a radial foundation 50cm thick concrete and rebar. I'd have to break the concrete to access the rebar and then connect a 16 mm2 earth cable about 2 meters from my consumer unit. Then reseal the concrete to prevent corrosion.
My power is coming from a 10000kva inverter with a 60 meter long 16 mm2x2 10mm2 earth cable just for your info.
How would I go about bonding copper earthing wire to the rebar, isn't this going to corrode (more) quickly due to the potential between different metals?
We don't have wylex here. I only found hager single pole rcbos. I put a 100 ma rcd infront of the rcbos. So I'm thinking the 30 ma rcbos should trip before the 100 ma rcd.
Reply to Ring circuit cable length in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
In addition, can you show the junction box with the cover off? Isolate the supply first, obviously. It sounds strange, what you’ve described at...
Who knows? There's this, in the OSG app H: "Permanently connected equipment should be locally protected by a fuse complying with BS 1362 of...
