Ring circuit testing | on ElectriciansForums
Discuss Ring circuit testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi there
What would you do?
Scenario
Double switched socket is faulty, just requires a replacement,
Carry out essential tests first,
ze
Ipfc
Earth continuity and bonding
etc
IR tests
Do you remove leads from disconnected mcb to allow IR test,
do you just do lives to earth or do you go around, remove all items from ring circuit and leve all switches on, checking for any obvious spurs or fcu,s etc then do live to earth, live to neutral, live to neutral.
I have had funny readings sometimes with lives to earth giving around 10MOhms readings, sometimes, surge protectors giving these readings, so it is a pain for me as well as client to hunt around the ring to find and remove all possible devices, as this increases the time taken for a simple socket replacement.
So would you not be raising a mwc for a socket replacement.
No way, unless it was commercial or a rental property.
There's enough paperwork with this job without creating more. The schemes recommend we do, but they can provide me with a secretery if they want that much paperwork.
Reply to Ring circuit testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Not all sockets isolate both the live and neutral when you turn the switch off Many just isolate the live leaving the N connected. So the...
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
