Ring continutiy r1 fault. | Page 2 | on ElectriciansForums
Discuss Ring continutiy r1 fault. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
and when you find the poor connection you will find that your R1+R2 comes down to around 0.3 ohms.
I understand how you've calculated to this but I would be expecting a few spurs off the RFC, so I would probably assume a higher reading than 0.3
Reply to Ring continutiy r1 fault. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Often, but not always: 543.2.9 Except where the circuit protective conductor is formed by a metal covering or enclosure containing all of the...
Very technical :D
