Ring final continuity readings............. | Page 2 | on ElectriciansForums
Discuss Ring final continuity readings............. in the UK Electrical Forum area at ElectriciansForums.net
M
mickytuff
Hi all had a weird one today, actually make it two, tested ringfinal continuity at the board lives were 0.00 and so were neutrals, earths were the same too, not sure why, is it a ring that has been interconnected causing a duff reading??
Secondingly tested another property's ringfinal circuit and got 30 ohms, very high- across lives an neutrals, earths were 49 ohms.........has anybody discovered similiar readings as i need to put an observation against these results and i would be even happier if i knew what they suggested/what was wrong with these circuits?? :sad_smile:
My testers fine, batteries fully charged, and checked readings on my spare meter, exactly the same so the readings are correct, i think the ring is interconnected very close to the board and is duffing the reading up hence the 0.00 which is obviously not a correct/compliant reading as it suggests no resistance............there must be a reason for it
Ok if you think the ring is interconnected close to the board why did you not open a socket at the half way point and test there. I would suspect ring leaving board probably straight to a JB then on to sockets.
Reply to Ring final continuity readings............. in the UK Electrical Forum area at ElectriciansForums.net
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
