ring final | on ElectriciansForums
Discuss ring final in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
domestic spark
hi, was approached today by a spark that had done a board change, blah to cut a long story short........................
he said i had two ringmains one upstairs and one for downstairs. when i used my bell testers to check ends so i was sure i was connecting right ends togther back as rings in 32a breakers, it belled between all 4 line ends in ALL combinations? what does this mean?
from hearing this i wasnt able to give a certain answer? dont know anymore than this as i havent been to the job.
but has anyone got any ideas please??
rings bridged. but bell test??? what happened to correct measurements??? R1, R2, Rn.
You cant give a certain answer....the only certain thing is something is far wrong and needs investigating.....most likely wot telectrix said.
if its a basic continuity tester and there is something plugged in on each circuit its possibly picking up thru the nuetrals if they are all still connected?
Reply to ring final in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
Yes that will do the job - presuming there is a battery in it and it's working Ok! Turn the rotary knob one click to the V setting as you say...
