Ring finals and fused spurs | Page 2 | on ElectriciansForums
Discuss Ring finals and fused spurs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That must be total length of cable then. But for sure the OSG also states an A1 RFC is maximum 100sqm floor space.
For a 100sqm room you could be using any length of cable from 20m to over 100m in length, dependant on the route the cable takes etc.
for VD on a spur, I'd estimate the length of cable from one end of the rfc and add the spur length, then use mV/A/m. this would give a pessimistic figure as the VD on the rfc part would be less.
Reply to Ring finals and fused spurs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I created a voltage drop spreadsheet for this sort of thing. I used to use it to calculate the drop when designing regular 230V lighting circuits...
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
