Ring main become 2 radials | Page 4 | on ElectriciansForums
Discuss Ring main become 2 radials in the UK Electrical Forum area at ElectriciansForums.net
Naz
London
Electrical ring circuit
The electricalian came and did the second fix. But we werent sure if all the wires had been bought through the plaster board.
All the sockets work, but we wanted to make sure there are no wires hiding in the walls.. we tested by disconnecting one of the 2 lives going into the fuse.. when we did this we tested the 11 sockets ..they all worked except the one just as you walk in the LR.. when we switch the lives at the fuse, the one in the LR room now works but the other 10 stops working.. this tells us that we have again unintensionally created two radial circuits both ending with an exposed live wire in the wall somewhere...1 radial has 1 socket .. and the other radial has the other 10.. and we have a break between socket 10 and 11.. any suggestions how to resolve?
Is it be to remove the outgoing cable in the single radial.. and then find where the rouge outgoing wire is in the other 10 sockets..
So in summary:
Its a garden annex being constructed / converted for domestic use
Spark A first fixed -
OP is doing the building work
Spark B has started 2nd fix
No evidence of any testing
Socket circuit has "continuity" issues
Lord knows what the rest is like ? The submain?
This falls under part P of the Building regs so you need an EIC and Part P cert
Sounds to me like the OP needs a 3rd spark to perform surgery with a hammer on the property to locate the cables ......
Good luck with that!
Oh dear,what a thread.Your main problem is now to sack the present electrician(I use that word loosely:() and get someone who knows how to use an insulation resistance meter and can find the fault by testing and a methodical approach on how it's wired.
You paying a 5WWW to just switch on and then scratch his head is not helping your bank balance or your families safety. That's why you pay someone to do it because they have the experience to do the job.If your present joker was decent he should hold up his hands and say he hasn't got the experience and stop charging you for his incompetence.
This sounds like a poor communication problem between whoever is doing the building works and the electrician. It's perfectly acceptable to install cables in ceiling ready to retrieve after plasterboarding and skimming provided that the location of said cables has been carefully noted . As others have said, the 2nd electrician should have dead tested prior to energizing to ensure continuity, ins resistance, polarity etc. I would advise that as project manager the OP finds and pays a reputable electrician to carry out the remedial works before it gets further out of hand.
Lets simplify this rather erratic thread, all you need to do is locate the missing sockets and your problem is solved. Theres no point moaning about holes in the walls as im sure you would benefit from the missing sockets.
Will - apologies for the erratic nature of the thread.
I will be finding another electrician to come and do the shower/ water heater and get him to do a proper test on the whole circuit.
in the mean time, to make it "safer", I have removed the outgoing leg on sockets 10 and 11, taped them up and left in socket, that way i know that in the meantime I don't have any live wires in the wall and the electric can be used while tiling etc takes place.
In summary, I therefore now have 2 radials feeding off the same fuse at the CPU (the original IN and OUT live wires from the ring have now become OUT and OUT at the fuse)
I appreciate this may result in loading issues, but we will only be using one socket at a time for now.
I just have to decide weather i want to take down walls etc or retro fit a 2.5mm between sockets 10 and 11 to complete the ring.
The worrying thing is that a qualified certified electrician simply checked the plugs all had power and said "the ring must not have any breaks as all the plugs work"...then left me fot 2 weeks with live wires in the wall... i had no idea what a ring was at the time but some simple background reading outlined this, ..Also I now know that even if he doesnt have the testing equipment, in order to check the ring doesnt have breaks, all he had to do was drop one of the legs at the consumer unit and check the the live leaving the unit was actually returning in the dropped leg.
We also had issues when wiring up a double switch.. i had to tell him he needs a link cable and that was the reason why the lighting circuit was stopping after the first light.
Poor guy just paid 7k for get qualified, he is a very nice guy who i think might be out of his depth. Suppose with time on the job he will pick up these issues. Its a good job i was able to point out some of the issues, even though im not an electrician..
With this level of knowledge he should not be taking on paid work in people's homes. Some people aren't aware of their limitations unfortunately.
That's the trouble with 2nd fixing someone elses work how many times has a plasterer filled a box or boarded over one then u go back it's hard enough remembering ur own work Personally I'd look for a place in between the leg with 1 in and the closest socket from other leg and in between those 2 there will be somewhere a socket would be handy chances are thats where it is .Or if it a Friday afternoon just put each leg into it's own 16 A echo or whatever and make sure u disconnect the outgoing cable on end of each leg and Get to pub
Reply to Ring main become 2 radials in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
What is the distance from the point outside the house to the shed?
