OP
eganelectrical
So can someone def confirm that if you are adding on To an existing (non rcd) circuit then you need to make this rcd protected?
Discuss Ring main spurs and replacement of lighting fittings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sorry, I neglected to say that if you want to do it properly you can use these.
3.5mm x 35 NYLON PLASTIC COUNTERSUNK PHILLIPS M3.5 SCREW NUT & WASHER PACK OF 10 | eBay
I have a slack handful in my fixings box if I need them.
Reply to Ring main spurs and replacement of lighting fittings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
