Ring or Radial....? | on ElectriciansForums
Discuss Ring or Radial....? in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
Im am soon to be installing 4 double sockets and possible 2 wall lights in a new conservatory.
Was going to extend downstairs ring but a tad awakward and I'm not a lover of junction boxes if they can be avoided. The consumer unit isn't too far so just as easy to install a new circuit.
I'm debating whether to go for a 2.5mm ring, 2.5mm 20 amp radial or a 4 mm 32am radial. If the wall lights are required then will be fused down via a FCU.
Obviously less Cable to run with radial and I can't imagine there will ever be much load on the few sockets.
Opinions much appreciated :)
Speak to the home owner and see whether they will have elec heaters on in winter in there, and what other things they may use the sockets for.... If they plan on watching the tv whilst ironing and with a couple of fan heaters on then 2.5mm might push it. Is it a big conservatory? Just thinking re heating aspect... I suspect a 20A would prob suffice.
Cheers guys, that was my thought too :)
What's the general rule for wiring t&e in a brick cavity in a conservatory with only the bottom half bricked?
Obviously its more in depth for a fully bricked property with insulation, foam, likelyhood of being drilled etc.
I believe it may be brickwork then plasterboarded so would a short piece of plastic conduit between floor and socket be a better shout before its plasterboarded?
You need to determine this before making any decisions!
It's generally not even half bricked, more like 5 or 6 courses!! I have no problem using the cavity on such installations, done it myself on a friends conservatory.
Don't worry about anyone telling you that the cable will be breaching the cavity gap and it'll cause damp, that's always been an old wives tale, and remains so to this day!! lol!!
re cables in cavity walls...........has that been banned by regs? I know it appears to be a pain re above job.
4mm radial all options covered then
What?
Only a Electrical Trainee that’s afraid of the calculations for a ring would suggest that.
Being of the old school, I’d run a separate ring and a new lighting circuit.
Think about it, you have to run the 4mm[SUP]2[/SUP], so why not 2x2.5mm[SUP]2[/SUP] and a 1mm[SUP]2[/SUP] Split the two circuits either side of the board.
BTW I’ve never had to work to a budget
What?
Lucky you!! If I didn't work to a budget I wouldn't have any customers! 20A radial will murder it surely, who sits in a conservatory with 2 fan heaters going all day?
What?
dont agree with you tony theres nothing wrong in running 4mm radial you can put it on a 20a breaker if you want and im no Electrical Trainee and i can also do cable calcs the op was mentioning possible heaters getting pluged in hence why i went for 4mm cable no point running 2.5mm and the finding out hes pulling more than 20amp oh and the cable could possibly come into contact with insulation in the cavity and have its current rating capacity dramatically reduced
Reply to Ring or Radial....? in the UK Electrical Forum area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
