Ring or Radial....? | Page 2 | on ElectriciansForums
Discuss Ring or Radial....? in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
Im am soon to be installing 4 double sockets and possible 2 wall lights in a new conservatory.
Was going to extend downstairs ring but a tad awakward and I'm not a lover of junction boxes if they can be avoided. The consumer unit isn't too far so just as easy to install a new circuit.
I'm debating whether to go for a 2.5mm ring, 2.5mm 20 amp radial or a 4 mm 32am radial. If the wall lights are required then will be fused down via a FCU.
Obviously less Cable to run with radial and I can't imagine there will ever be much load on the few sockets.
Opinions much appreciated :)
Thanks for all the responses.
Quick update.
- 4 double sockets and 2 ceiling lights to install.
- Sockets only required for tv + 2 lamps
- Approx total length of run = 20m
- 100mm insulation in cavity (brickwork with plasterboard)
There is one spare way in consumer unit so my plan is to put in a 20A 4mm radial supplying 4 x DSSO's and 1 x FCU (to feed the light switch + 2 ceiling lights in 1.5mm)
If the loading of sockets is increased in the future then the MCB can be increased to 32A.
Cables will run underneath the existing floorboards then clipped to the joists in the new conservatory then up through the cavity with 100mm insulation. Only approx a total of 5m of cable will be surrounded by insulation, including the lighting cable fed from FCU.
Sound ok, any suggestions?
Reply to Ring or Radial....? in the UK Electrical Forum area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
