F
Fin170
My standards are very high, always have been and always will be.
Sorry bud didn't mean you personally, in relation to earlier discussion in the thread :wink5:
Read my post #102 mate, the doom mongers are always predicting it's imminent demise, purely conjecture rather than evidence based fact.Whilst I was on my 17th course when it first came into power our tutor told us that it was more than probable that when the 18th is introduced the ring main will be no more for new installations.........has anyone else heard this?
I disagree - plug everything into a ring and it balances itself. Customers don't care about balancing circuits and will plug everything in where they want.multiple radial circuits are far better than a couple of rings, obviously the negative side is a larger consumer unit, the positive side is the fact you can reduce load by balancing across several circuits, a no brainer IMO.
and also 2-3 sockets max on a radial would illiminate overloading due to the lack of outlets on the circuit,
but with several circuits if RCBOs are used the chances of collective earth faults very unlikey and nusience tripping the same.
I see your first point but will never agree 1 ring is equal to several radials, just impossible IMO, it just doesn't make sence to me and never will.
This linear thread is going round in circles... :joker:
Ah well now you're talking about 'nuisance tripping' in which case I would agree. You didn't mention that in the previous post; I was talking about overloading - a customer could happily draw 30A from upstairs or downstairs continuously from any room, while they couldn't with a 20A circuit unless you have one radial per double socket, which seems like a waste of copper and CU space (not to mention money), and unnecessary considering BS1363 plugs contain a maximum 13A fuse.Thats the worse statment I have ever read, anyone who knows about electrical Installation practice would know that several power circuits is more practicable than a single ring, I'm not against rings by the way, I would always have at least 3 in a house, however, for starters you could have several 20 amp 30 MA RCBOs protecting several circuits and the nusience tripping would be a hell of a lot less than on a ring, and also 2-3 sockets max on a radial would illiminate overloading due to the lack of outlets on the circuit, I would suggest 4mm2 radials on 20 amp circuits myself and radials for fridges and freezers seperate again, a ring with a heavy load isn't balanced, it can be overloaded and due to collective earth faults very annoying for the house holder due to nusience tripping, but with several circuits if RCBOs are used the chances of collective earth faults very unlikey and nusience tripping the same.
The maximum you can draw off it continuously is 26A though.Here is a question for you..
For arguments sake... Consider a standard ring circuit (32a Mcb 2.5mm conductor) It has an additional socket spurred off of one point.
Now imagine the extra spurred socket is wired away from the board, so there are 3 conductors in the Mcb, still conforms to the regs.
So therefore the cable that feeds that spurred socket is protected by a 32a Mcb and it is allowed.
Now disconnect the ring cables.
Suddenly that spur doesn't comply anymore...
Does anyone else find that a little strange?
Or to put another way..
A 2.5 radial feeding 1 socket is fed off a 32a Mcb.
"not protected!"
But if you don't have an appropriate Mcb on the van, it doesn't matter, we'll just run in a couple of new legs to a new socket and bobs your uncle it's all tickety boo now because we've changed it to a spur off of a ring and that's fine!
That'd make it a ring then?![]()
It's a hypothetical question..
32a Mcb is overrated for a 2.5 radial, but chuck a couple of cables in and suddenly it's okay..
A 32A MCB is overrated for a radial circuit run in 2.5 but it is not incorrect for one double (or single) socket outlet on 2.5.
Because the nature of the load is such that you cannot have an overload as the socket outlets will use fused plugs that limit the maximum current.
So where there is a situation where there cannot be an overload there is no requirement to provide overload protection, only fault protection and the MCB will provide fault protection.
In your example having a single spur off the MCB for a ring and then removing the ring would be still compliant with the regulations, however you would not be able to add outlets to this (now) radial.
hi there
Reading this thread with interest, changing the subject slightly how are grid switches wired for kitchens, these are becoming more common
Many Thanks
hi there
Many Thanks
