S
simonspark
Hello all. I think this question may have been asked before, but how good are Rointe oil filled rads. Please help quick, because I may be buying 2 on the morrow, Thanks.
Hello mate. CEF are charging me £412 for the 1.2 KW and £325 for the 770W. Plus VAT
Hi ,, I cant track down the trade prices but CEF offered me 15% off, i then rang Edmundsons and they quoted me 35% .
CEF rang me to check if i wanted to order , and they fell over when they heard i was offered 35%, as that is what CEF get,
He spoke to the rep to find out what was going on as he thought they had an exclusive deal and the guy said no and that the discount was offered to all
So avoid CEF unless they give u 35%
EDDIE
Rointe heaters are oil filled aluminium radiators. They are claiming 60% energy saving, but having read the report from BSRIA, all it says is that a 1.6kw rad was used to heat a room with 1kw/hr heat loss and it used 1kw/hr. Any electric heater with an electronic thermostat will do exactly the same. All electric resistance elements are 100% efficient at turning electric into heat, so providing that the appliance has an electronic thermostat to accurately maintain the room temperature then all electric heaters will give the same energy usage and the same running costs. Rointe heaters are nothing special and cost stupid money.
Yes u may be right , but why are we complaining its more work for us, And plus you can turn one on at a time useing the remote control hence saving energy.
Also no more gastly copper pipes
The point I was making is that there are lots of electric radiators on the market with very similar control capabilities and that Rointe rads are no more controllable or any more energy efficient than any of the others, despite their wild and untruthful claims. If you pass on their energy saving claims to your customers, you will only get hassle later when the customer gets a huge electric bill. Electric radiators certainly have their place, as a controllable alternative to storage heaters ( and much better looking ) BUT there are other products which are just as good, or better than Rointe - AND much cheaper.
Ha! Ive finally fitted 2 of these heaters. and yeah, they seem pretty good but are very expensive. However the customer was very happy. They cost about the same as a storage heater with boost control
Be warned though. They do not come supplied with the remote control, that costs extra. And the other thing is this. They come supplied with 1 metre of flex which has an outlet on the right hand side of the heater. The heaters I fitted were a metre wide. The sfcu for the heater was on the left hand side. Ergo the flex was not long enough. And if you try to open up the heater to put on a longer flex the warranty is void. Lets just say mini trunking at skirting level, crimps and heat shrink sleaving!
Oh and I managed to get those lovely Rointe boys to send me a remote FOC. One remote does any heater.
I didnt hang around to see how quickly they heated the room up because the weather was strangely already warm considering it was a June afternoon! But they look good.
One last thing though. If you have a wall with dodgy fixings, you may struggle because youre rather limited to how it fits to the wall. Hope this helps
G
garyevans
G
Rointe
Electrical Tools and Products
simonspark,
jpdevine,
