Discuss Round conduit box lids. in the UK Electrical Forum area at ElectriciansForums.net
Never had an issue, get the boxes, get the lids/gaskets, brass screws - happy days..
Where did you buy your gear from?
Tower, which I thought was a good brand. One of the online videos' someone done regarding bending of the conduit and it splitting and breaking. I think that it is light gauge.Wow that sounds terrible, I’ve only ever used MT and Centaur..
What make do screw fix sell?
I’ve installed a load this weekend from Screwfix
Screwfix, never again.
Thin conduit lids that bend before they are tight and let in water, and screws that’s gave badly rusted in 5 weeks.
The lids have delaminated as well.
take it back.The quality is poor for a lot of things, Schneider heavy gauge plastic conduit is the most recent problem causing conduit item for us. The bore of the conduit is now off centre leaving one side of the wall much thinner than the opposite side. This has lead to problems with bulging and distortion when bending. This is not just a one off bad length of conduit either, we are on bundle number 7 now with the same problem. Getting sick of using it now.
Tower which Screwfix sell is now part of the Schneider brand we have had this problem with other brands. The PVC conduit sold under the Schneider brand used to be Miter (if I spelt that correctly) which used to be high end.The quality is poor for a lot of things, Schneider heavy gauge plastic conduit is the most recent problem causing conduit item for us. The bore of the conduit is now off centre leaving one side of the wall much thinner than the opposite side. This has lead to problems with bulging and distortion when bending. This is not just a one off bad length of conduit either, we are on bundle number 7 now with the same problem. Getting sick of using it now.
Used to install their type B distribution boards about 8 years ago and they were a good board with the slider bar. Recently we had to fit an MCCB board with meters on each side it was terrible compared with Eaton load of leads to connect where Eaton one supply cable pre-made plugin leads between meters and a cat 5 from the meter to CT's. How have they made a mess of the Merlin board?Mita.
Sadly Schneider ruin a lot the products of the companies they take over. Look at what a mess they made of Merlin stuff.
Reply to Round conduit box lids. in the UK Electrical Forum area at ElectriciansForums.net
