Running Cable under floor with UFH? | Page 2 | on ElectriciansForums
Discuss Running Cable under floor with UFH? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
the only problem is that i am installing some floor boxes and the insulation has been put down already :rolleyes:
could i put 4mm down so the heat has less impact on the cable? or would heat resistant cable do the same job
You’d have to redo your cable calcs with the right cf.....heat resistant cable is resistant to outside influences not the load on the cable cores..
Reply to Running Cable under floor with UFH? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
im just assuming that they are designed to be surrounded by material, and would heat to a certain amount, spreading the heat into the material...
R
Large format stone on UFH timber suspended floor- a job for Ditra matting? Hi all, I'm doing a barn conversion at the moment and the ground...
robbyraven
R
