Running Cables in Purlins | Page 2 | on ElectriciansForums
Discuss Running Cables in Purlins in the UK Electrical Forum area at ElectriciansForums.net
IAmSparkytus!
Newcastle Upon Tyne
Hello
Couldn’t find anything in the forums on this and thought I would have…
Large warehouse, minimal power circuits, two or three lighting circuits, max of 5 three phase circuits.
Would it be acceptable to run these within the metal purlins at roof level and tied in place or would tray hung from purlin clips be required?
Trying to avoid this if possible as some of the tray may be ran 30m for the sake of one cable for example
Are they z purlins? Ie theres already a trough formed for you to lay them in? NYYJ layed in there would be fine by me, they aint ginna fall up! But if its farm or risk of vermin I'd use swa. Use beam clips to support things if you need to traverse any other steels or vertical drops
To add just be aware of grouping
I see and have put cables in purlins as you describe, but its never the first choice. If the cables are inside the purlin you are only one screw away from cable damage if a roofer or cladder come along. You would be surprised how long the screws used by roofers can be. "Why use a 2 inch screw when i have a couple of hundred 4 inch screws", lol -
If i was planning from scratch i would use my own containment, see it as an investment for the future
Ive only ever done it after a roof is on, and no ceiling is being fitted, ie its all left exposed
I am referring to subsequent cladding and roofing upgrades to insulated roofs, i have had it on two buildings where repairs / upgrades have damaged cables (not ones i have installed, i might add... :cool:
Reply to Running Cables in Purlins in the UK Electrical Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
