Running tails through loft space | Page 2 | on ElectriciansForums
Discuss Running tails through loft space in the UK Electrical Forum area at ElectriciansForums.net
tomodo
United Kingdom
Hi just installed new tails and moved consumer unit, cables are about 7 metres long they run inside a cavity from meter and i have then clipped on top of loft joists , on one bit though there is a heating pipe so i have gone under and clipped to side of joist.... i realise cables have to be 50 mm deep when drilling through joists does this also apply when clipping to side?
Some DNO's get funny about you installing your own equipment within the meter cabinet/box but on the other hand they don't want you relying on their fuse for OCP for your distribution circuit..I would install a switch fuse within the cabinet/box with no qualms.
Reply to Running tails through loft space in the UK Electrical Forum area at ElectriciansForums.net
im just assuming that they are designed to be surrounded by material, and would heat to a certain amount, spreading the heat into the material...
Passing through the wall should be in conduit to protect the cables. Yes cables should be clipped.
