The easiest way of wiring in the UFH is just to treat it as a third zone in the heating. So assuming this underfloor heating is just one zone you would take a live (and poss a neutral) to a programmable room stat, take the switched live (and neutral) back to a 2 port zone valve; this operates the motor of the zone valve. Then all you have to do is connect the grey and orange,(the switch inside the valve) in parallel with the grey and orange of the other valves.
"Hello JD Hogg",
Underfloor Heating which is installed on the whole of a Ground Floor is often required to be used without the Radiator circuits of the Heating System - especially if those are on the First and Second Floor of the Home / Property.
This would mean that it should usually have its own Timeswitch - not a Programmable Room Thermostat - because as I am sure You know the Thermostatic Control of the Mixing Valve and the various Zones / Rooms within the Ground Floor [for example] are controlled completely seperately from the rest of the Heating System with Room Thermostats which control Actuators on the various Zones on the Underfloor Heating Pipework Manifold.
The Room Thermostats controlling the Underfloor Heating Zones obviously CAN be the Programmable type.
If the Underfloor Heating was wired as You described how would what I have described operate ?
Although people could turn down the other Room Thermostats - in this case for the First and Second Floor Radiator circuits - If Programmable Room Thermostats were installed - as is becoming more popular - that would not really be an option - because of having to lower the Set Temperature by the use of buttons - too much `messing about` for what is supposed to be a `Fully Controllable` Home Heating System.
I do NOT claim to know how to wire the Underfloor Heating - but I know how it is meant to be able to operate.
Regards,
Chris - Heating Engineer
