S plan heating system | Page 3 | on ElectriciansForums
Discuss S plan heating system in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hey guys. I got this information off the plumber today, we’ve got 3 wireless programmers, 3 x 2 ports (heating) 1x 2 port for the cylinder,frost stat, 2 x secondary heating pumps (they’re the main system heating flows,stats will control these)2 x primary heating pumps (shunt pumps) cylinder stat, and secondary return hot water pump ,
2 x Worcester 40 cdi classics, 2 x grundfos 25/80 SF pumps, 2x grundfos 15/60 PR pumps, 3x Honeywell 2 port valves (heating) , 1 x Honeywell 2 ports (hot water circ) cylinder stat, frost stat and grundfos gold pump HWSR, #CONTROLS# 3 wireless single channel programmable room thermostats, 1 x wired hot water timer
It’s simple to wire if you break it down. It’s a lot of work to try and explain it or knock up a diagram. It might be easier if you do a diagram and I/we can tell you what needs changing etc if anything.
Reply to S plan heating system in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks I understand it now just getting to grips now with the different types and different ways of wiring them
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
