Safely split ceiling lamp for three bulbs. | on ElectriciansForums
Discuss Safely split ceiling lamp for three bulbs. in the Lighting Forum area at ElectriciansForums.net
Spools
Vienna, Austria
Hey all.
New here and new to 3 phase.
I had some electric experience on set in Los Angeles as a gaffer for a couple of years, but it was mainly single-phase - counting amps and avoiding blowing circuits type deal. Also did basic wiring in my old 73 chevy truck as well. So nothing huge.
But now, living in Austria, I'm met with 3 phase.
I have a kitchen ceiling unit that I'm looking to replace with a custom lamp.
(I've done some wood working and now looking to add 3 individual bulbs from this new unit as an overhead unit)
Question is, can I simply split the existing hot and ground three ways from the existing lamp directly to the respective three new bulbs/units I intend to have?
Yes
(assuming you're not powering theatre lights 🤪)
Haha - LED - under 60w each - dimmer at switch. Straight forward.
I suppose a better question is, what is the best way to split it?
Divy it up three ways, connect and shrink wrap?
I'm a bit of a perfectionist with this stuff and having trouble envisioning the cleanest way to do this.
Depending on the space available, what you can buy, and local practice, you might use push-in connectors as below
or the lever type (assuming your wires are the appropriate gauge!)
Instead of trying to split 1 wire into 3 wires,
go to the first light, cable in and a second cable out to the next light, rinse and repeat as necessary
Thanks, guys.
I curbed this project for a couple weeks, but back to wrap it up.
I like the plug and play idea of a connector.
Amazon.de is showing poor results - I see this here
But I don't like the design with how all of the hot is left, and all of neutral right for example.
I found this on google, which looks much cleaner as I can simple keep each L/N together for each lamp:
What do you guys think? Any thoughts on that product?
It's rated at 9amps... I can't imagine I'll draw nearly 20% of that on 230v.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
The wagos already mentioned. I'm sure they're available throughout Europe.
I see you're in Austria, the only place I can now watch F1 live from, thanks to ORF and Servus, without paying exorbitant fees to that crook and general scumbag, Murdoch
Haha. I stay away from cable TV as I did in the states, but watch ORF and Servus at the in laws the same way Fox News hits my parents when I’m home.
My go to has always been SKY when watching games back in the states. I think they’re English though.
I receive ORF and Servus via the internet and synchronise it to a live sound commentary from an English radio station.
Sky is Murdoch, and they provide excellent coverage of F1, in exchange for many hundreds of GB pounds per year. Full F1 coverage is also available worldwide on F1TV, via the internet, at the very reasonable cost of about £60 per year, but this is blocked in the UK by Murdoch and Sky.
I'd be amazed if German made connectors were unavailable in Austria.
Murdoch had SKY too?! Sticky paws man…
I’m surprised the syncing works for you, but I’m glad it does! I would usually have a delay of a play or two when streaming NFL games.
You’d be surprised the trouble I have working my hobbies in Austria. There’s a boat load of rules and regulations when working on autos.
They don’t have nearly the same amount or similiar products for wood working at the local OBI (Home Depot.) I’ll have to go to a speciality store outside the city for contractors and even then, wood conditioner doesn’t exist, I had to make my own.
Electricity wise, let’s see, I never really got my hands dirty in this realm here yet. I tried out a dimmer in the office but, for whatever reason struggled. (That’s a different post altogether.)
Reply to Safely split ceiling lamp for three bulbs. in the Lighting Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
Definitely looks like the cpc (earth) has been sleeved and used as a neutral conductor, this is not permitted. You are going to need an...
