Scotland, Old style lighting JB, Will it pass an EICR, Photo attached | on ElectriciansForums
Discuss Scotland, Old style lighting JB, Will it pass an EICR, Photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Edinburgh
Hi
I have taken on a kitchen rewire, with a utility & bathroom addition too, In the loft there is an old style junction box for the lighting circuit, I've seen this method before in many old council houses, Its fed from a 10A mcb with 1.5mm t&e & it is a central point for lots of loop fed switching & a common for many feeds, basically just allowing many parallel connections.
I was always trained to wire in series for lighting, keeping my neutrals at the switches, I'm wondering if this breaches any wiring regulations, The maximum load does not exceed 10A for the over all circuit, the 1.5mm t&e feed is about 10 meters & does come through some light fiber wool insulation, so I'm happy that no cable carrying capacities have been breached, & currently plan to tidy up the JB somewhat, with some extra earthing & better connections.
It will be a minor works certificate for this one, as there is no new circuit.
Thoughts please, would you pass it?
[ElectriciansForums.net] Scotland, Old style lighting JB, Will it pass an EICR, Photo attached
Hi
I’d be worried if you are wiring lighting in series connection.
The main issue you have here is that the adaptable box is not earthed but fitting a separate 6.0 cpc is not necessarily the easiest solution. The other issue in my opinion is that terminating 8 or 9 conductors into block connectors is never going to provide a connection of ensured integrity.
Its rough
The box is not earthed
The cables do have strain relief via the clips
The earth sleevings are iffy
The blue of the old 3 core was not sleeved black (a bit irrelevant nowadays)
The connector blocks are floating
Black live switch wire no id
Black conductor of the new 3 core just lobbed off
Finally ( at least I think so)there is no lid :)
Other than that,I have seen much worse than whats on display
Above comments aside,nothing wrong with a junction box that is accessible,they can have advantages over loop in at lights and/or switches
Reply to Scotland, Old style lighting JB, Will it pass an EICR, Photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
