Scotland, Old style lighting JB, Will it pass an EICR, Photo attached | Page 2 | on ElectriciansForums
Discuss Scotland, Old style lighting JB, Will it pass an EICR, Photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Its rough
The box is not earthed
The cables do have strain relief via the clips
The earth sleevings are iffy
The blue of the old 3 core was not sleeved black (a bit irrelevant nowadays)
The connector blocks are floating
Black live switch wire no id
Black conductor of the new 3 core just lobbed off
Finally ( at least I think so)there is no lid :)
Other than that,I have seen much worse than whats on display
Above comments aside,nothing wrong with a junction box that is accessible,they can have advantages over loop in at lights and/or switches
It is certainly rough, the earth sleeving will be upgraded, core id's will be rectified, will fix a the connectors, the lid is off at the moment. so yeah with all those issues sorted I think its a pass
if it was me get a some thin MDF place inside the chocolate box.
get a strip of block connectors screw to the MDF and tidy up the cables job done .and don't for get to put a lid on!
I find the cable below the box which appears to have cotton covering and red, blue and green conductors more interesting even though it is probably dead.
Nah. Handful of Wagos and 20 mins and you can have that spick and span and safe. I quite like octopus wiring, where everything meets at a convenient and accessible point. Poking a load of CPCs in one choc block is no good but a couple of 8-way Wagos will sort it all out nicely.
No idea what you want with a 6mm CPC & it doesn't need bonding. It's an accessory, just earth it to the CPC like you would a metal light fitting.
That's actually Blue / Orange / Green because it's an old phone cable.
Could change it to one of these there are more way units available.
  • Surewire 6 Way Pre-wired Lighting Spur Junction Box SW6S-MF - T.pdf
Reply to Scotland, Old style lighting JB, Will it pass an EICR, Photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
Which begs the question, where does the second brown wire come from?
