SDS and Combo Drill Recommendations | on ElectriciansForums
Discuss SDS and Combo Drill Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
RDB85
Trainee
Liverpool
I’ve been asked by work to get some power tools. Currently I’m using what the other engineers have. But I would like to get my own. I am after recommendations.
I would have thought this thread would have had more replies by now! lol Everybody on here loves tools it seems!
Or - oh no Superlec don't sell actual drills just bits by the looks of it. So yeah, just E2Go for drills sponsor-wise I think.
I use Milwaukee M18 and M12 tools for everyday work. Excellent relaibility and performance. The fuel series are the better ones, but if you're on a budget the ones labelled "brushless" sold in screwfix and toolstation are ok, just older models is all.
I'd also look at Makita and Bosch professional if you are looking at a platform to build a kit on.
I'm a DeWalt fanboy.
18v brushless stuff for me.
Milwaukee stuff is very good too The guys I know with it have nothing bad to say about it.
The Makita combi drills seem not to last, based on the opinions of others who have had them.
You can get some good deals on kits but make sure you check the exact model numbers in the kits as some key tools can have lower spec versions.
This one of 'em?
I'm not convinced a 12v SDS would be up to much other than very light duties.
I could be wrong though... It happened once before... a while back. :D
That will all depend on your budget. Just remember big brands like Makita, Dewalt, Millwaukee etc will all have different models ranging from budget normally sold in B&Q, Wikes etc then the middle range normally sold in Screwfix and then you have their top models normally online unless you live close to the retailer.
Most SDS drills will range from ÂŁ100 up to around ÂŁ600-ÂŁ700 for the brands top models. Personally my favourite SDS of all time was a Hilti superb bit of kit, you then have the Makita 36v the Dewalt 54v's Bosch 36v all great bits of kit.
I have that little guy. Got it in a twin set with the 12V combi drill. Both are really good little tools with plenty of grunt used with their 6Ah batteries. I mainly use the sds for smaller masonry drilling, usually 5.5mm and it will go all day doing that. I have used it with 16-22mm masonry bits at 600mm long and it will just about cope with that, but it takes a while and drains the batteries quickly. The 18V sds is definitely the boy for that stuff.
The main reason for the 12V stuff is weight saving. I can use the 12V sds all day one handed no problems, but the 18V is much heavier.
Wot Andy said.
I've been using Milwaukee for 12 years now. Only had one drill fail, I wore it out - my first 12v combi drill, lasted 8 years.
Milwaukee looks good. Is the M18 Fuel range good? As I’ve found a Combi Drill for £250 online brand new. Should be £350.
Or would this be better:
I’ve also seen this Dewalt for £200 online:
The Milwaukee M18 Fuel range is the best out there at the minute. The combi drills have the highest torque of any available combi drill and mine minces through joists no problems. the combi drill is the M18FPD2 or M18FPD for the previous version. I think they are essentially the same tool, just the newer FPD2 is slightly lighter and smaller.
ÂŁ250 is just slightly on the cheaper side of the going rate for a new version Fuel combi with 2 x 5Ah batteries and a charger. I can find that deal at ÂŁ270 on quite a few websites I have had tools from before.
The toolstation Milwaukee items there are older dated stock with a bit less power, but still good. I have that combi, bought it 6 years ago and still going good although I did have to replace the trigger once.
The DeWalt kit looks a good deal if you need an impact driver. Not used DeWalt myself though so can't comment on it really.
Thanks Andy. This the the Milwaukee Fuel one: Milwaukee M18 FPD2 FUEL Combi Drill
I would rather have an SDS than an Impact. So it’s older stock. There is one on eBay for £300. So I’m not sure what to do. As the Milwaukee Fuel one for £250 looks a bargain based on what’s they go for online.
Got a link to the deal you're looking at ? Like I say ÂŁ250 is good but only just cheaper than ÂŁ270 .. which is readily available.
Reply to SDS and Combo Drill Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Yet another vote for the biggest and the littlest. I use the big SDS solely for chasing (you still need it if you have a chaser as it doesn't get...
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
