SDS and Combo Drill Recommendations | Page 3 | on ElectriciansForums
Discuss SDS and Combo Drill Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
This is the model I have
That must be a long time ago Tel, my 18v does 25mm holes with a metre long bit and a bit of light tracking work too, and can't fault it, at times I consider buying another body only for when we are busy.
they must have improved then. mine was pre Li-Ion. metal halide or whatever. i retract my comment if you'll retract your not cool. :):):)
[automerge]1569754293[/automerge]
i have... ... bin/skip.
comment retracted. apparently deWalt are OK these days.
I did also look at Metabo and Bosch Professional. I suppose when you look at it you have to consider the whole range. Milwaukee or Dewalt seem the popular choice. I found that kit on eBay with 10% off for £273 posted which seems good value. But then I found that Dewalt kit for £200. It then comes down to costing for the other drill whether it’s an Impact or an SDS including batteries which would be the most cost effective option.
The 2 brands with most options are makita and dewalt. Imo makita is not what it was back in the day.
So dewalt has to be the best option for choices of tool variety.
I have 2 combo drills, 2 impact drivers, sds, angle drill, electricians stapler, floodlight, angle grinder, multi tool and circular saw.
My mate with the milwaukee M18 range has sent his sds back for repair 3 times in 2019 and his combi drill is away at the minute and was away a few months ago for a new trigger switch, he thinks my multi tool is more powerful as well, personally I didn't like his as the battery goes in at an angle and doesn't stand up straight. So needs laid down every time.
As a M18 user I've not had anywhere near this many problems. SDS is solid and takes heaps of abuse (CHX model) I have had a trigger replacement on an older combi (M18CPD model) But that was after 4-5 years of daily use. That's the only repair I have ever had to do on any of my M18 kit.
Yep the multitool is a bit basic but does the job. I do like the DeWalt multitool though, very nice bit of kit indeed.
Thanks for that Phil. Certainly interested. Only thing with Dewalt that is confusing is the model numbers for each. Being new to it, it’s a mind-field as I am not sure what’s good and what’s bad.
thing is, as you say, it's a minefied. once you make your choice... 1 brand so interchangeble batteries, you're stuck with it. a trade fair like elex is a good idea, so you can see what;s on offer and handle the tools, find out what's best for you. maybe even get a good deal.
That would be a good idea. Bit far for me to go though. Shame there is not something in the North West.
I could go the Wholesalers and Toolstation etc but they are limited in what they have. There is a Power Tool Centre Ltd, 49-51 London Rd, City Centre, Liverpool L3 8HY they seem to have quite a bit of stock. Might try there.
Makita stuff is still more than good, just stay away from the basic models as they are more for DIY. I've the DHP481 brushless combi drill and it's an absolute weapon.
@RDB85 I'd recommend trying out and having a play with as many different brands as you possibly can - get a feel for what you like using. Personally in the past I found the Milwaukee stuff too bulky and cumbersome, typically after I had bought it. What works well for others, might not be best suited to you.
Reply to SDS and Combo Drill Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Yet another vote for the biggest and the littlest. I use the big SDS solely for chasing (you still need it if you have a chaser as it doesn't get...
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
