Serious question | on ElectriciansForums
Discuss Serious question in the Australia area at ElectriciansForums.net
J
jono1987
Hi all, serious question, i highlight this as i am aware there are various witty answers to this but...........
Do you use magnets as an electrician ? and if so what type ? i am not allowed to use strong magnets for medical reasons.
Thank you all in advance for your response.
As an electrician it is possible to come into contact with various electromagnetic equipment ( contactors, relays) and electromagnetic fields. I would suggest you would need to more closely define how strong the magnets are you cannot come into contact with
Other problem would be that electricians don't go round measuring measuring the magnetic fields they come into contact with unless they are involved in R.F. work
Hi There
I would avoid being near induction hobs a customer of ours ordered one and when we went to instal we noted on the instal instructions thatif you have a pacemaker you should avoid induction hobs, not sure how true this is but her GP told her not to use the hob
Danny
Reply to Serious question in the Australia area at ElectriciansForums.net
Yes, supply via buried SWA from the main dwelling into new CU. The main house is TT. New CU to have RCBO on all circuits. The workshop area will...
Type of washer Hi Team, I have a leaky radiator as it washer must of got damaged when it was fitted Anyone know what this washer is called? And...
dwaindigital
