Shared neutral | on ElectriciansForums
Discuss Shared neutral in the UK Electrical Forum area at ElectriciansForums.net
scotland
I was at a job today replacing a db and wiring supplies for an ASHP. The house used to be owned by a company who let them out (there's another 6 houses) as holiday cottages. The supplies were from a central board in cupboard on the site. The houses have been sold off and part of the deal was that they would pay for individual dno supplies and meters in outside boxes at each house . A firm was employed to run supplies from these meter boxes to the existing db's in the house. They have run a 3 core Swa terminated in a tp 63amp mcb using brown for live, black for off peak live, grey for neutral and the armour as the cpc. To me this isn't correct but I'm looking for of you guys expertise. Inside the house it was terminated into a 4 pole isolator and split into seperate db's. I was removing the need for the off peak supply so I fitted a switch fuse and used the Swa using a core as L,N&cpc but the other properties are as described above.
It's single phase, not sure how long it's been like this, maybe 6 months. On one of the other houses that's using the new supply (there's been loads of balls ups with getting correct meters fitted so some houses still using the old supplies) theres shower, cooker, 2 storage heaters, immersion, 3 panel heaters. It just doesn't seem right in my head but I could well be over thinking it. I'm not looking to get shot down just seeing if anyone else thinks it's not or likewise if there's nothing wrong!
Sorry about the poor explanation guys, wish I'd taken photos. The house that I'm working on is fine now as I've altered it but if it's wrong I think the contractors need to fix it. O have another house on the scheme to do work on and make this Swa live so I need to know your views.
Don't like the idea of 4pole isolator, shutting off both boards, if that's how I have read it.
The regulations require, quite sensibly, that an installation should have one main linked switch or circuit breaker which isolates the installation.
How would you achieve this without the 4 pole isolator (obviously it could be 3 pole in the situation described)
With the neutral going through the TP mcb then there is linked overcurrent protection in the neutral so the cable has adequate overcurrent protection.
But obviously that's not the end of the story.
The regulations require that each circuit has it own neutral and that neutrals not be shared. So is this one circuit or two?
As the two lives are supplied from the one OCPD I think you would technically class it as one circuit and so the setup is ok.
Conceptually I think it is a cost cutting exercise, and would be questioning the bonding arrangements for the properties as the steel armour won't comply as a main bonding conductor.
So the general consensus is that it's ok as it's "one circuit" apart from the size of the main bonding conductor? Still don't really like it but hey ho! What if, for arguments sake the domestic is pulling 50amps and the off peak pulling 50amps. Dont know if I mentioned it is a 16mm cable.
Reply to Shared neutral in the UK Electrical Forum area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
Why would the RCD fail … yes it can happen but then it may not. Without it you have no protection on the TT System
4K
