Discuss Shed/Garden Electrics? in the The Welcome Forum area at ElectriciansForums.net
Main reason was because the main switch is 63amps, I know that means that's what the switch can handle not what SHOULD be fed before anyone jumps, I've got a 20amp mcb and a 6 amp so a 30 amp mcb from the house would do on 4mm if I'm not right correct me?
So you are going to rip out the 6mm cable you claim you already installed in post #11 ?
Pure fantasy this thread
Yes.. Is that a problem if yours? I can get cable not a problem
20A is more than enough for the capacity you require so for a 10M run you could have used 2.5mm 3 Core SWA.Main reason was because the main switch is 63amps, I know that means that's what the switch can handle not what SHOULD be fed before anyone jumps, I've got a 20amp mcb and a 6 amp so a 30 amp mcb from the house would do on 4mm if I'm not right correct me?
Required Cable Size | 2.5 mm |
Voltage Drop | 2.61 Volts. |
Percentage Drop | 1.1% |
Current Load | 17.4 Amps |
Max Cable Load[SUP]*[/SUP] | 21.4 Amps |
But why would you do that ?
The more I read this the more I despair, as the thread has moved on I have read your posts and then looked back at this, is this post correct or are we still with the 6mm2 cable in on a 32 amp MCB now? or is it a 35 amp and a 4mm2? is the run 7 mtrs or 20? what about the extra future lighting load? or are we at the 2.5mm2 off the ring circuit? confused . com here.I want to put a 2 way consumer unit into my shed to feed 2 outdoor sockets and a couple of spot lights.
I have bought the CU with a 63 A main switch, 1 x 20 amp for sockets and 1 x 6 amp for lighting,
now my question is, can I take a supply from my kitchen socket (fed from a 16 amp mcb) through the wall to the shed in 2.5 mm or 4.mm cable into the 63 amp main switch?
If that's not sufficient then what size cable to go from my house CU to shed CU (under 20 meters away) and can i connect that to a 35 amp mcb or do i have to connect it to a 63 amp?
I don't want to do a FCU as I may add more lighting in the future and a CU looks neater.
Thanks, Ryan.
Well I don't have to I'm going to leave it but I meant that 4mm cable could handle that load
To be a good liar you have to have a good memory Ryan. I too am now convinced this is all BS. Congratulations on sucking a lot of people in, I hope you enjoyed yourself.Well I don't have to I'm going to leave it but I meant that 4mm cable could handle that load
You have a 20amp and a 6amp MCB? Simply double them up and hey presto you've got a 26amp MCB!
are you part p registered?
As owner and installer you will be doubly screwed if not
It's very basic work but the consequences of getting it wrong are potentially dangerous or even lethal.to be fair I never thought of looking back through my stuff, it was just a pretty basic question that could have had a basic answer as it is only basic work!
You don't have sufficient test equipment to work safely or test the installation correctly.yeah I've got a multi meter but have access to a MEGGER so thats not a prob........
Reply to Shed/Garden Electrics? in the The Welcome Forum area at ElectriciansForums.net
