A
Aok1
I am bulding quite a large shed next and i need to get some power in. We currently have a re-wireable fuse board with 30mA rcd on the incoming supply.
I was going to run a 6mm swa from the board to the shed, terminate in a metal box then into a small CU with a few MCB'S.
Just need clarifacation on 2 things -
The supply is TNC-S but the shed will not have any conductive parts so i can export the earth?
No RCD needed in the shed CU? Discrimination problem if i did fit a RCD
