Shed Supply | Page 2 | on ElectriciansForums
Discuss Shed Supply in the UK Electrical Forum area at ElectriciansForums.net
essex
Hi have a situation have wylex 4 module metal clad consumer , RCD, 32mcb and 6 MCB, trouble is main consumer no where near the back of house and all fancy flooring, there is a shower supply 6mm upstairs on a 32 mcb in the consumer , its an old GE series consumer unit and the shower on the 32 is not RCD protected, only the ring is, which they will not be needing anymore, was thinking of connecting this to the swa 6mm in a box then run swa out to shed 70 ft run , any ideas here thanks
well strange you should say that I am no guru on regs I look then up if I need to, but posted a similar question on extendiny a ring main in a commercial premises and was slated. over rcd protection so check my regs and phone elecsa and was basically told if extending the ring then I need to rcd it or if I add a new ring rcd the od can remaine as long as I don't alter it.
well strange you should say that I am no guru on regs I look then up if I need to, but posted a similar question on extendiny a ring main in a commercial premises and was slated. over rcd protection so check my regs and phone elects and was basically told if extending the ring then I need to rcd it or if I add a new ring rcd the od can remaine as long as I don't alter it.
But this extended ex shower cable is no longer a final circuit as such, it's now a sub-main cable supplying a CU/DB which in turn then supplies final circuits....
i think I'm going to upgrade the outdated CU to a main switch unit CU and RCBOs on every circuit, this will be for my niceic assessment once qualified 17th edition, Part P. ill get to the garage supply at a later date ill just make sure i leave a spare gang for her ;o)
Reply to Shed Supply in the UK Electrical Forum area at ElectriciansForums.net
Do you know what percentage of scheme registered electricians are registered to sign off 3rd party work? Even better would be a poll of how many...
nicebutdim
N
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
