Shock from Dyson handheld battery vac... | Page 3 | on ElectriciansForums
Discuss Shock from Dyson handheld battery vac... in the UK Electrical Forum area at ElectriciansForums.net
Deuce
Stamford
So, here is one to debate.
Wifey bought one of the cordless V8 dyson vacs, on the basis that all her friends have one. It's pretty handy.
But today I discovered an unusual feature. If it detects the motor is working too hard (in this case as the filter was blocked with dust), it will switch off until you release the trigger. However... As it cuts out it sends a hefty shock back out the charging port, sufficient to transfer into the palm of the user - in this case, me! After the first and second shock, I took it over to a radiator and held the charging port next to it, sure enough each time it cut out it would arc to the radiator. Each time I released the trigger before it cut out, no arc.
So, did Dyson protect against this problem, but only if the trigger is released, not if the vac cuts itself off - basically an oversight? Or is it perhaps some cruel way of forcing the user to clean the filter? :)
I did google, found this and others: https://forums.whirlpool.net.au/archive/2531043
Theories? I suspect the stupidly fast (100,000+ rpm) motor builds up quite some floating voltage which might be responsible for this 'feature'.
“Are you sure it was just digestive biscuit crumbs you tried to suck up?”
[ElectriciansForums.net] Shock from Dyson handheld battery vac...
The motor is a high frequency squirrel cage induction type fed buy an inverter, so I suspect this static caused by friction with the carpet.
It happens repeatedly even when holding it mid-air, and only when it cuts out itself, never when the trigger is released to turn it off.
I'm convinced they have snubbing for the flyback but for some reason the circuit doesn't work if the trigger is still held down when it cuts out.
I'd be interested to find out. It would make sense that when the trigger is released, the current is sent to a cap and held as a charge to kick start the motor when it's next turned on - such an arrangement could explain why de-energising the motor with the trigger held results in the current not having a path to the cap as intended.
Reply to Shock from Dyson handheld battery vac... in the UK Electrical Forum area at ElectriciansForums.net
