So, here is one to debate.
Wifey bought one of the cordless V8 dyson vacs, on the basis that all her friends have one. It's pretty handy.
But today I discovered an unusual feature. If it detects the motor is working too hard (in this case as the filter was blocked with dust), it will switch off until you release the trigger. However... As it cuts out it sends a hefty shock back out the charging port, sufficient to transfer into the palm of the user - in this case, me! After the first and second shock, I took it over to a radiator and held the charging port next to it, sure enough each time it cut out it would arc to the radiator. Each time I released the trigger before it cut out, no arc.
So, did Dyson protect against this problem, but only if the trigger is released, not if the vac cuts itself off - basically an oversight? Or is it perhaps some cruel way of forcing the user to clean the filter?
I did google, found this and others: https://forums.whirlpool.net.au/archive/2531043
Theories? I suspect the stupidly fast (100,000+ rpm) motor builds up quite some floating voltage which might be responsible for this 'feature'.
