Shocked by Main Earth Cable | Page 2 | on ElectriciansForums
Discuss Shocked by Main Earth Cable in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
And theres me thinking putting an earth clamp on a service cable was an absolute no no.
clamping the lead sheath of a cable with a clamp = compression fault = BOOM!
..........Use an earth-leakage clamp meter around the cpc's or use it around the live and neutral together which will give you a reading of the difference between them, ie the amount flowing to earth.
I think you may be misunderstanding my suggestion. I was talking about using an earth leakage clamp meter around the incoming L+N tails, I wasn't suggesting he install an earth clamp on the incoming cable.
Reply to Shocked by Main Earth Cable in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
