Hi,
I need a short height 6 way consumer unit around 200mm total external height or less, in order to fit above a doorway. It is replacing an existing bs 1361 fusebox.
Can be RCD as I expect rcbos to be ruled out due to being taller anyway.
Any ideas? Not even sure if such a beast exists, may have to troll thru all the Manu's specs.
The alternative will necessitate extending all the cables to reach around to an adjacent wall, which would be a real drag.. Literally!
Cheers in advance..
Cheers in advance..
