sima24
Hi all, long story so i appreciate if anyone makes it to the end
A lad i know and his friend have started working for a local housing association rewiring houses, changing boards etc. At first i was pleased for him as hes a nice guy but soon became clear they were totally incompetant. He had a fault last week and asked me to pop round and help find it, i found it within 5 minutes amd was shocked at the work i seen, to name a few:
- every circuit put on 1 rcd and the other rcd blank
- wrong size shower cable
- cables not in safe zones
- no bonding to water and 6mm to gas
- 2 inch holes around consumer unit top
- no sleeving on switch cables or cpc's
- neutrals stripped so far back about 3 inch of copper showing on lights and sockets
- MAIN FUSE BLOWN AS THEY HAD CONNECTED THE BUSBAR ACROSS MAIN SWITCH L&N RCD L&N PLUS ALL MCBS (and they couldnt understand what they had done wrong)
- smokes 10mm away from light fittings
- no isolation on extractor fans
I was absolutly stunned at this, and the 3 bed rewire had taken nearly 3 weeks.
I was in stiches when he asked me if i could sign it off as neither of them are part p registered.
Obviously they are not up to the job of completing any sort of work to standards but im more concerned with this housing employing them and looking at their work as acceptable! And also breaking the law as these two guys are not part p registered and building control have not been notified of any of their work? Im tempted to report the housing association as the standard of work i have seen in my opinion is going to kill someone sooner or later, either a tenant or one of the "sparkies". What would any of you do?
