Discuss Should I use 1mm or 1.5mm earth in domestic lighthing? in the Domestic Electrician Forum area at ElectriciansForums.net
Might change your mind if you were taught correctly in the first place Middy.
Practice and craftsmanship, maybe?I don’t see a problem with doing it with a knife. I just think it’s a faff and more risk of catching the cables. Trying to get your knife in a small accessory box is a pain.
I have always used either a Klauke or Thomas Betts scoring tool,which whips round the periphery of a circular sheath,with an adjustable depth,swivelling cutter. A couple of spins,and then pull off the end,results in the sheath coming off like an onion skin.Just as a matter of interest @PEG how do you strip the outer sheath of SWA without the aid of a sharp implement?
Reply to Should I use 1mm or 1.5mm earth in domestic lighthing? in the Domestic Electrician Forum area at ElectriciansForums.net
