Might change your mind if you were taught correctly in the first place Middy.
I have always used either a Klauke or Thomas Betts scoring tool,which whips round the periphery of a circular sheath,with an adjustable depth,swivelling cutter. A couple of spins,and then pull off the end,results in the sheath coming off like an onion skin.Just as a matter of interest @PEG how do you strip the outer sheath of SWA without the aid of a sharp implement?
Reply to the thread, titled "Should I use 1mm or 1.5mm earth in domestic lighthing?" which is posted in Domestic Electrician Forum on Electricians Forums.
