The old "my friends an electrician" ploy!!On these type of threads the "Electrician" always seems to be on holiday
Discuss Shower Consumer Unit Wiring in the DIY Electrical Advice area at ElectriciansForums.net
Well with the money they earn its not a surprise they go on holiday so often hey !!! Now I'm looking for help not to be criticised over having a go myself
every step I have taken has been taken from advise from a friend
Its those kinds of inconsistencies that raise questions about the posters mhmm?researched what Consumer unit and RCD's I needed
The thing is @Shmeefly, how is the cable routed to the shower? Is it in stud wall with insulation? or underfloor in insulation or just tacked to the wall all the way to the shower? It is important. The cable is not 10mm² it is 6mm². Which may well be ok for a few reasons. You say in your first post you researched what you needed then later your electrician/friend advised you
Is the RCD operating within the required spec too?I have just pressed the probes of my MFT on the terminals in that photograph.......and it's live!
(IR's good,though...)
Well on the basis of the facts presented it would seem you may be safe to get in the shower. I would insist on you first though However I would just wait for it to be tested to be absolutely sure. So if I read it right, you have replaced a shower that was already there? It has been mentioned that you have a C type 40a MCB which can present problems for automatic disconnection of supply and may not switch off in time. Although at 40a you are in slightly different territory than the usual ring final circuit but never mind about that. I suggest in any event you change it for a B Type 40a MCB before anything else. It is more likely to be a safer bet.
And insulation resistance test, and EFLI and RCD....etcas well as do a continuity test
Yes I will be testing insulation and earth too
Reply to Shower Consumer Unit Wiring in the DIY Electrical Advice area at ElectriciansForums.net
