Shower Consumer Unit Wiring | Page 4 | on ElectriciansForums
Discuss Shower Consumer Unit Wiring in the DIY Electrical Advice area at ElectriciansForums.net
. Electric showers can be dangerous things if not done properly
Especially when installing using probably the cheapest MCB/RCDs around.
If you had test kit all along and the knowledge with which to use it, then why did you need to ask the forum if it all looked ok ? Why did you not just test it ?
What test kit do you have ?
I'm going to hire a Megger 1553 tom or tuesday to fully test it :) anything else
No not replaced new install, the people who had the house before, started installing it then sold the house, and thanks again Vortigern I will replace with a B type tomorrow :) as well as do a continuity test :)
Red & Black cable, when did they start installing it, 2004?
I thought I was slow at home improvements:tearsofjoy:
and i've only just finished off my last 2.5mm red/black T/E last week.
If I'd known how much old colours stuff would be worth today, I would have put a load in storage back in the day.
Reply to Shower Consumer Unit Wiring in the DIY Electrical Advice area at ElectriciansForums.net
Sounds more positive.
In the UK the safe current for a cable is determined by considering how it's installed, eg under insulation, or buried in a wall, or in conduit...
