Shower feed wired in wrong | Page 2 | on ElectriciansForums
Discuss Shower feed wired in wrong in the UK Electrical Forum area at ElectriciansForums.net
1stfix2ndfix
I was wondering if anyone can answer this one for me. I'm an electricians mate, I did ask the guy I'm with but he couldn't give me an answer.
So after he changed the board and I did the bonding I get to go round testing. Whilst taking the zs of the shower I noticed immediately upon removing the over that the feed had been wired up wrong. The live was with the live but the neutral from the feed was wired up to the earth terminal/cable in the shower and likewise the earth from the feed was wired up to the neutral terminal and cable of the shower. Now spotting this I asked the customer who had wired this up as they have done it wrong and I was told the fire fitter lol. She then asked me why it had worked and was still working. I didn't really have a answer and nor did the guy I'm with if I'm honest so I'm just wondering if anyone knows the answer to that one. Was it unsafe and were they just lucky. I felt a right idiot not knowing the answer but hopefully next time I'll be able to fill em with confidence in my response
That could not have happened as the first thing he does is to cut into the tails and pop a rcd in the middle. If this trips out we know we've got problems. So that is weird either he didn't do it (not likely) or there's something else as the feed coming in was Deffinenty wired up l-l n-e and e-n.
The plot thickens...
So before he changes the board he sticks an RCD inline with the tails and if this trips you know you have problems?...
ha ha no way!...is there no testing carried out?...(other than the bang test)
Testing seems to be cut into the tails and put a rcd in. If it trips then we've got problems if not good to go.
So I'm wondering should the rcd have picked up on this
What tests should of been done and what one would have shown me that the nutral and earth were mixed up in the shower unit before I even looked in there?
no way of finding that fault without opening the shower unit apart from RCD tripping as soon as the shower was used. i've already said that if you read my previous posts.
Reply to Shower feed wired in wrong in the UK Electrical Forum area at ElectriciansForums.net
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
Hi there , I wired it up following the instructions from similar model. Works great thanks for your help
