Shower feed wired in wrong | Page 3 | on ElectriciansForums
Discuss Shower feed wired in wrong in the UK Electrical Forum area at ElectriciansForums.net
1stfix2ndfix
I was wondering if anyone can answer this one for me. I'm an electricians mate, I did ask the guy I'm with but he couldn't give me an answer.
So after he changed the board and I did the bonding I get to go round testing. Whilst taking the zs of the shower I noticed immediately upon removing the over that the feed had been wired up wrong. The live was with the live but the neutral from the feed was wired up to the earth terminal/cable in the shower and likewise the earth from the feed was wired up to the neutral terminal and cable of the shower. Now spotting this I asked the customer who had wired this up as they have done it wrong and I was told the fire fitter lol. She then asked me why it had worked and was still working. I didn't really have a answer and nor did the guy I'm with if I'm honest so I'm just wondering if anyone knows the answer to that one. Was it unsafe and were they just lucky. I felt a right idiot not knowing the answer but hopefully next time I'll be able to fill em with confidence in my response
Testing seems to be cut into the tails and put a rcd in. If it trips then we've got problems if not good to go.
So I'm wondering should the rcd have picked up on this
What tests should of been done and what one would have shown me that the nutral and earth were mixed up in the shower unit before I even looked in there?
http://i.stack.Upload the image directly to the thread.com/jiFfM.jpg
I cant believe someone does that. An R1+R2 or R2 would of picked it up, one of the first tests that should of been carried out.
Installing an RCD in line is going to take longer than carrying out that test. As Tel says it doesnt prove much either because it would have to be switched on for it to trip. It is not the right way to do things at all.
Sorry to be a thickoo guys just reading this interesting thread and wondered whats an r1 + r2 ??
R1+R2 is one of two ways of carring out the "Continuity of Circuit Protective Conductor" test.
DEAD test, safe isolation and prove it's dead before carrying out the test
A temporary link installed at the C/U (or I prefer to take the live conductor of the circuit and put it in the earth bar), test at shower between Line & Earth with a continuity tester.
Then you would get your result in Ohms, and check that in accordance to table L1 On-Site Guide BS7671:2008
Reply to Shower feed wired in wrong in the UK Electrical Forum area at ElectriciansForums.net
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
Hi there , I wired it up following the instructions from similar model. Works great thanks for your help
