Shower Room | on ElectriciansForums
Discuss Shower Room in the Australia area at ElectriciansForums.net
T
tazmantic
Need some advice please all,
Now my dads getting on a bit I decided to turn the old built in wardrobe into a shower for him (perfect size 1100x760 shower base will fit a treat) and one wall backs onto the bathroom right next to the stack pipe other the airing cupboard with all the water i need :0) started on the job, not much really just removed a floor board to check waste route and removed a few shelves only to think after chatting to a mate will I need building regs...... Quick call to council and answer was yes :0(
So they sent me some forms and soon as I work out how to fill them in I will lol, question is what am I going to get for the ÂŁ140 it looks like there going to charge me????????? Also will I need to get the lectrics tested by a "competent person" ???????
There will be no new cables run in as there is already an inline fan with low voltage lighting that was installed years ago as used it for my computer etc, and in the airing cupboard there is a spare fused spur once again been there years but was going to replace the fcu with an rcd fcu as there is not one it the consumer unit........ the shower I intend to install is a power shower not one with a heater element init...
Any advice greatly received.....
Thanks for the reply IQ, and Im aware of that but there already there Im just connecdting to them and as the connection will be in the room next door is that classed as a special location.......
Thanks nikmet but Not what I wanted to hear lol, so how much is that gonna cost to get that tested?????? or does the building regs Ive gotta pay for cover that??????? thought I had read somewhere if there were NO connections in the shower room then it was ok.......
There are grey areas such as this when it comes to notifiable/non notifiable but seeing as it's a shower room and it's for your old Dad and it involves existing work that may or may not be up to standard, is it not money well spent to get a competent electrician in for a couple of hours to complete the work, test it to BS7671:2008 and notify it if he deems it neccessary?
you may also need to have the earthing checked? all these unknown areas will and should be done by a competent person who knows what they are looking for to meet your requirements..................it will be money well spent knowing that everything is done properly and to current regulation by a qualified electrician, and that it wont catch fire due to poor workmanship and the fitting of incorrect fittings for the job. Most sparks will give u a free quote and tell u what needs doing before u even think about parting with some cash!
Thanks again IQ and your right Ill just have to get the building regs guy out and see what he says, like I said Ill be fitting an RCD fcu and if I thought there was any danger with the wiring in his house I would not let him turn the lights on let alone use a shower.....Thanks
Hi ukpablo, yeah earthing was one thing I was thinking of though there is earth bonding in place, and "qualified electrician" thats ok then as I is one lol just not "competent"..........so what is the going rate for testing as neither of us is made of money.....Thanks
lol...............if ur qualified, then u must know?!!!! just get some quotes is my advice from a couple of sparks in ur area. Everywhere is different, so if ur qualified but not competent then surely u must be up to date with BS7671???
IM afraid u gonna be getting ur wallet out bud................being competent costs money as im sure ur fully aware of! i cant really say without looking at it so im absolutely no help to u whatsoever..........so good luck anyway, nice chatting! :earmuffs:
Qualified but not up to date (as stated in my other posts) always worked in industral not domestic and my employers have never wanted to train me any further (not for want of me asking) and finding the time and money to do the courses my self is difficult, so just really wanted to know if there were hard and fast rules but as IQ said there are gray areas......but thanks anyway
If you are getting labc in then they become responsible for the inspection and testing and your not a electrician and just doing it diy its stated in electricians guide to building regulations
a diy er has to notify before carrying out the works then the labc become responsible who will send a competent approved inspector to inspect and test the work and fill in cert as a diy er is not qualified to fill certs in
a qualified but not registered with a governing body electrician , has to notify complete the cert send a copy to them of the test results and labc become responsible for the work and will send a independent fully qualified approved spark to inspect and test and sign I&T and the qualified spark who is not registered signs for design and construction
a qualified and registered electrician is classed as competent and approved to carry out the work to the standards and is allowed to notify and self certify the work through the governing body ie Elecsa ,NICEIC etc who will notify labc of the work then a building completion cert will be sent to the client /customer
The grey area as I see it, is that the existing lighting and the extractor fan do not have RCD protection.
As they are existing, there is no requirement to upgrade them to current standards.
However you will be changing the use of the cupboard and will be turning it into a special location, in which the current Regulations require all the circuits to be RCD protected.
If you don't RCD protect all of the circuits, then you would have to install supplementary bonding, connecting the circuit CPCs and any extraneous-conductive-parts back to the CU.
I note that you intend powering the shower from an RCD FCU, the Regulations require the circuit to be RCD protected, not just the part that is spurred off of another circuit.
You may want to consider purchasing and installing a shower CU, I believe Screwfix and Tool Station supply these for around ÂŁ30-ÂŁ40.
Thanks brucelee, think that makes sense but will need to read again tomorrow as bit tired now, only contacted the council (labc) to see if I needed building regs but to be honest the guy my other half was put onto didnt want to hear any thing about what I was doing just said "yes need regs" end of, she had to ring back and speak to another person to see how we went about getting them. If you do it all the time yeah ok you know what to do but this is the first time Ive contacted them about anything so I have no idea, Im even going to have to ring up to ask how to fill the form in.......makes me think I should of just done it but I do like to do things to the book. Think I need to just fill in the form, get them out an see what they say.... Thanks Again
Thanks spinlondon, thats why I needed to ask on here lots of knowledge the fan is an inline one (motor and all connections in loft area) does this still need to be RCD protected?? also the spur I was intending on using has its own fuse in the CU (15A fuse feeding 2 FCUs in the airing cupboard via 2.5 T&E) one for the boiler one spare so was hoping I could use that for the power shower pump but was going to fit an RCD fcu for added saftey, I can install a shower CU but then will I not need to get it tested ?? I was hoping by using existing I could for go the need and expense of getting it all tested......... Thanks
Reply to Shower Room in the Australia area at ElectriciansForums.net
N
Shower drain cover - can I get something that will fit? The drain cover in my shower cubicle is flaking and discoloured. I was hoping to remove...
Neil Sutherland
N
Shower screen reinsert problem Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens...
Sandy283
