Shower Swap require RCD install? | on ElectriciansForums
Discuss Shower Swap require RCD install? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Manchester
Hi everyone.
Hoping to clear something up.
A maintenance person has asked me this question and I've heard a different views on the matter.
A block of flats have Electrical Showers in them, if he was to change one (like for like) is he by rights supposed to upgrade that circuit he has just worked on to have an RCD?
Thanks in Advance.
AP.
Welcome to the Forum :)
Last time I checked any showers 'installation intructions' I noted they all specify RCD protection or specify they must meet current regulations, as it is in regulations that manufacturers instructions are taken into account then IMHO if you want to cover your --- then I would say yes.
Why would you ever fit an electric shower without an rcd? who would benefit?
The lazy installer who can gallop off to another job with the time saved not fitting the RCD if it's not already present. Or the maintenance man or plumber who doesn't know or have the competence for the electrical side but can screw three wires in to make it work like the last one did.
The Landlord's pocket.
Exactly my point, you take the risk they take the profit.
The regs are a minimum standard, even if you don't have to doesn't mean you shouldn't .
Just my opinion of course.
Reply to Shower Swap require RCD install? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
2 3
