Shower timer | Page 2 | on ElectriciansForums
Discuss Shower timer in the UK Electrical Forum area at ElectriciansForums.net
Smithiesmith
I've been asked to install 2 electric showers. That's the easy bit. The client has asked me if I can install a timer so they will only run for a maximum 10 minutes. Is this possible? The reason is to stop the kids spending hours in the shower and save on energy.
As Andy78 says. Then if you get one that wont listen to you then give them 5 minute warning and then switch off the shower at the CU.
Trying to use timers is going to be hassle as you will need two timers. 1 for how long then shower is on for and 1 for how long the shower should be off for. If you just have 1 timer, (say controlled by the light switch) then what is to stop them getting out of the shower when the timer trips and just switching the light off then on again to get the shower working again.
[ElectriciansForums.net] Shower timer
Hi,
Non electric solution it is interesting I think.
Thank you.
bertt.:bat:
Hmmm sad times when kids won't do as they're told and measures like this are necessary. Wouldn't have happened when I were a lad!
How true, the growl of my dads voice and I was out and dried in 2 minutes.
- - - Updated - - -
Never heard that before, care to further enlighten me!
Re OP, where are you going to locate this timer and how are you going to reset it?
Can imagine kids, covered in wet soap froth, wandering around trying to mess with electrics to get the showers going again.
Seems like a daft idea to me. Fit low power showers instead.
Well some showers run on after you switch them off to cool them down, so switching shower off from the mains I would think wouldn't do them any good
Sounds like a rubbish design to me. To cool it down you have to turn off the heating element (which as Robson says 'If the shower is off no more heat will be generated so it will cool down on its own') or run cold water through it. The last thing I would want it when I turn the shower off it carries on, but pumps out cold water over me.
Reply to Shower timer in the UK Electrical Forum area at ElectriciansForums.net
I doubt the terminals in those are suitable for 4mm, more likely designed for 1.5mm as they are limited to 16A. You could use the time switch to...
davesparks
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
