Shower upgrade with slave consumer unit | Page 3 | on ElectriciansForums
Discuss Shower upgrade with slave consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Torquay
I am upgrading my shower room and will be getting a qualified electrician to do the work but I want some advice so I can ask sensible questions!
I will be using a previous feed for an electric shower from the consumer board (down graded amps wise, which he has said is acceptable) and want to have a small "slave" consumer unit for a fan heater, extractor and lights. I want it as small as possible. It can be mounted in an area outside zone 1 and 2 but there will be potentially some humidity. I have seen a Plastic unit rated at IP44 and some metal units rated at IP40. It seems more sensible to ask for a plastic one with better protection but the regs say consumer units should be metal. Are plastic units, which are still available from reputable wholesalers, legal in this situation?
Consumer unit in bathroom = bad idea generally due to damp/steam etc.
And not needed - the shower can be fed direct, and the other items can be tapped off the existing circuits.
In my opinion anyway.
Oh yeah I’m with you there dpg,I don’t understand why the op wants it there at all, surely if the existing shower cable tests ok use that,everything can be extended from existing or spured (fan heater) or have I completely missed something?
Oh yeah I’m with you there dpg,I don’t understand why the op wants it there at all, surely if the existing shower cable tests ok use that,everything else can be extended from existing or spured (fan heater) or have I completely missed something?
Reply to Shower upgrade with slave consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
2 3
