Im a bit of a novice when it comes to relays etc so if anyone could help out with a diagram of how i would go about it that would be great!
thanks for the reply dude but if you read the first post I am referring to the side lights (on the side, as I have added the US spec wheel arches which come with side lights in them) and NOT front side light.
I want all the controls to stay OEM so adding lights on another switch isn't really an option.
Side lamps are officially called Position lamps, hence their position at both the front and rear of a vehicle, height from ground and distance inwards from extreme edge of vehicle.
Amber lamps at each side of the vehicle are not side lamps or position lamps, they are officially called outline side marker lamps to the best of my knowledge. :wink5:
