Siemens logo | Page 2 | on ElectriciansForums
Discuss Siemens logo in the Auto Electrician Forum area at ElectriciansForums.net
I think you would be better, rather than that diagram, just listing the inputs and outputs.
Then a breif explanation as to what you want them to do.
E.g input 1 - indicator right
output 1 - flashes when input 1 in energized.
I could write you the software pretty quickly on my lunch break if you provide such a document.
However, I'm far too far away to download it for you. I would only be able to provide the software.
The previous owner has lost a copy if re program and no cable. I wiped the program as after alternator problems I wanted to reset the logo to put everything back . I think me messing in the early days list a few good circuits and so now I'm forced to start again to see if all is ok . The logo operates perfect just empty I have been able able to program some basic but need a fill programme to run the circuit in my diagram .
When you can't find any paper indeed look in your daughters school bag !
Of course, you can also have the fancy functions you get on a new car, like flash indicator 3 times for a momentary push on indicator and continuously when held on etc.
Hi all just to provide an update .. I now have everything I need to complete this . Software and cable. So can anybody please provide me with working circuits for the repair of indicators to flash on button press and stop in button press. Hazards to flash on button press and stop . Fog light to operate as it should . Main beam . Side lights and headlights. I will post 2 new pictures of the inputs an outputs that hopefully is a little clearer. Thanks
Reply to Siemens logo in the Auto Electrician Forum area at ElectriciansForums.net
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different...
A fully charged car battery should have a resting voltage of 12.6 volts
