Hi all
does part p allow you to notifie another sparks work
thanks
Rich
thanks
Rich
Discuss signing off part p in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Larger companys who employ a few sparks must do it all the time?
They will be registered at a higher level. Remember the clue is in the scheme title "Self Certification"
then the answer must be yes part p does allow signing off.
................of course there is nothing to stop you doing this, but it would mean you would be claiming that you had done the job
NO NO NO you can not sign off other work as a part p installer,, as stated above if you are a full niceic then you can sign off other work ,
part p was brought in to stop you signing off work,,
Part P brought in to stop you signing off work???? What?
Question was about Part P and signing off! Not if you was niceic approved or a niceic domestic installer.
Reply to signing off part p in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
