Forty4
Just been back to a job that I upgraded the DB in and water bonding in November to find the plumber that's fitted a new boiler has cut my bonding to the water main. Now I've got to run the whole lot again FFS.
Discuss Silly plumbers!!! in the UK Electrical Forum area at ElectriciansForums.net
I thought about crimp but was not sure if it was ok under the regs as it is not continuous?
/QUOTE]
THAT would depend on how good you are at crimping!!
BUT if you're in any doubt, solder it .. and it WILL be continuous.
Ha I think I can crimp or solder well enough. You learn something new everyday cheers guys saves me a headache.
thats why i like soldiered joints.i'd use a non-insulated butt crimp and cover with a bit of gn/y heat shrink. i'd probably forget to slide the h/s on first and have to cut and re-crimp, thought.
Not done properly, then.heat it up and off it comes
depends on the solder.Not done properly, then.
Morning Mark. :santa3:
Reply to Silly plumbers!!! in the UK Electrical Forum area at ElectriciansForums.net
