Forty4
Just been back to a job that I upgraded the DB in and water bonding in November to find the plumber that's fitted a new boiler has cut my bonding to the water main. Now I've got to run the whole lot again FFS.
Discuss Silly plumbers!!! in the UK Electrical Forum area at ElectriciansForums.net
you're correct, biff. it's geordie not took his senility pills.
The solder in soldered joints is to prevent oxidation.
The joint should be electrically and mechanically sound before soldering.
Not done properly, then.
Is crimp on lugs any good bolted togethet, or is that clsssed as not continues as can be un done ???
because he crimps then solders, in that case it is a waste of solder.What makes you think that???
i always thought MDJ's first name was mike ??
well im not writing out another xmas card so he'll just have to remain as mike till next year.
I didn't say that.because he crimps then solders,
its not mdj its mdfIt's like Trigger always calls Rodney Dave innit!!
Gasp, now I am upset chucklenot to worry , i was lying about the xmas card anyway :-D
Reply to Silly plumbers!!! in the UK Electrical Forum area at ElectriciansForums.net
